I installed my nismo fpr, and boost controller. I got my fuel pump and it's ready to be put in. Am i supposed to add 1 lb of fuel pressure to every pound of boost i want? I got a t25 set at 43psi of fuel pressure right now. I want to run 10 pounds of boost. thanks
sleeper
what's your fuel managment? if you're using JWT programmed for the stock 3 bar fuel pressure; pull the vacuum line and set the fuel pressure to 3 bar (roughly 44psi, I'll let you figure out the exact number).
thanks for the reply.I got the fuel pressure at 44.. my question is.. im supposed to add 1 pound of fuel pressure to every pound of boost i want right?
^ thanks man
