if anyone could tell me where and what the fuel pressure regulator looks like, it would be a big help
It's hooked up to the fuel rail. it has a vacuum and fuel line connected to it. If u have a low port motor,it's under the intake manifold
shift_boost
follow your fuel lines one is attached to it
I forgot to add... if u are changing it... take out the fuel pump fuse and start ur car 2 or 3 times till it dies. then change it. the 2 screw holding them in are a bitch so don't strip them! get a good screw driver and while ur turning, tap the screw driver with a hammer constantly... it should get it off. good luck
