sergofast said:
whats the difference in sr20s in a FWD vs a RWD car? I have a 510 that I want to put a sr20de into (turbo later). It already has a 280xz transmission, and I understand that if you change the bellhousing then the sr20 will bolt to it. And, I have a couple extra sr20s from various b13 SE-Rs that I could use. From what I can tell, the intake manifold is different and the distibutor is on the side instead of the end of the head. Is that the only difference and if so, can i get a FWD sr20 head and use my bottom end? By the way, the 510 kicks butt and people stop and look with the blank expression, "what the #$&^ is it :rofl: Im giving it to my dad for Christmas (he is always bragin on his 510 he used to drive).
The 280zx trans will not work, whoever told you that is smoking crack. You can use a KA24DE transmission on a RWD SR engine however(I dont know about FWD). But SR/KA transmissions are not hard to come by so it is a mute point.
In addition, the FWD engine does not have the alternator in the right spot, and the oil filter would get in the way of the RWD intake manifold.
Dont bother trying to make a FWD engine work, it is way too much work and will end up costing more than just getting a 180sx front clip. The RWD engine is better anyway, piston oil squirters, low compression, sodium filled exh valves, shot peened rods, etc, etc...
If you are really serious about the swap and not just blowing smoke up our asses, you have the MONEY, time, skills, resources, tools, Fabrication knowledge, then I can help.
I did the swap into my 510 and did everything myself, EVERYTHING!
I must say that it is incredibly scary fast. The tires break loose at any speed when it gets up into the boost and the rear end fishtails around. You need some serious tires in order to put any power to the ground, like at least a 225 wide Toyo T1-S or RA-1 tire. I have T1-S's on the rear that are 215 and I find it spins them all the time when I try to run high boost, 17-18psi. Your quarter mile times will suck because of this.
Besides the engine swap, you are going to need upgraded brakes, roll cage/bar, at least a 4-point harness, rebuild the front suspension/steering,descent seats, limited slip diff, and anything else that has to do with safety.
I have a write up on how to do the swap, like mounting the engine, etc.. that I am working on. contact me if you are interested.
It is a lot of work and very expensive to get it going. Lots of custom parts...
I am just warning you before you throw a bunch of money at it and expect it to go smoothly.
