your computer is not dead. you problem is your head temp sensor. change the head temp sensor. if the circuit in the computer that controls the fans was bad, then the fans wouldnt turn on at all. if the head temp is bad the fans will be running all the time. the car stumbles and idles bad because the computer is put into limp mode because of the head temp sensor being bad. it is the way that the computer tries to save the motor when something goes wrong. it will turn on the fans to run all the time, it will dump more feul to make up for a lean condition, and will pull back timing electronicaly to reduce knocking or pinging in the motor. truely nissan computers rarely go bad, unless they are supplied the wrong voltage or handled improperly. if i were you i would try gettting a new head temp sensor instead of a computer. computers are getting hard to find these days.
