I will be going with the F-MAX stage I kit and will not boost past 10 psi. I wanted to get a three gauge setup. I am thinking boost and oil pressure. Any ideas on what the 3rd should be?...I know the A/F gauges are useless (according to mike kojima). I was thinking maybe a fuel pressure gauge? Any ideas on the gauges and what brands to buy? Also where should I get the pillar pod? Thanks in advance,
-saaby
Red 99 SE with: CAI, KYB AGX/Ground Control 350 in/lb front 300 in/lb rear, Stillen Front STB, Redline MT90, ES Motor Mounts (4-set), Timing changed to 15 degrees
-saaby
