1 - 9 of 9 Posts
If you're running the same size tire a 4.17 gear would make the car go faster than a 4.7 at the same rpm, IF, the trans ratio is the same. 5th gear will probably be a touch different but 4th should probably be the same. The 4.7 gear will give a harder pull, but will not run as fast at redline.
1 - 9 of 9 Posts
