1 - 20 of 26 Posts
Discussion Starter #3
Slow 96R said:
OK so what happens if you swap the B15 final drive for the B13 or P11 final drive. Would that increase the top end speed?
That would lower the maximum speed. But you cant just swap around final drives. You have to swap the pinoin gear that goes with that final drive or your tranmission will sound like an airplane.
OK these numbers seriously puzzle me as I am not sure what I should be looking at...
I have a b13 with a b15 se transmission...should I be looking at the b15 se numbers??
3rd gear topping out at 134.40 @ 7500RPM's sounds off a bit no??
Maybe I'm looking at the right sheet.
lmk!!
-B
Turbo Spicy Orange
so what this is saying to increase acceleration a b15 tranny is better than a b13???? **** top end i wanna take off like a rocket, anyone notice a big difference in swapping a b15 tranny into a b13 ser?
Bonesmugglar said:
so what this is saying to increase acceleration a b15 tranny is better than a b13???? fu*k top end i wanna take off like a rocket, anyone notice a big difference in swapping a b15 tranny into a b13 ser?
PM Stratton. He is selling a VE tranny.
European P10 FWD gearset:
1st: 3,0625
2d: 1,8261
3d: 1,2069
4th: 0,9268
5th: 0,7333
final drive: 4,1765
JDM P11 4WD, with Viscous LSD:
1st: 3,3333
2d: 1,9545
3d: 1,2857
4th: 0,9268
5th: 0,75
final drive: 4,375
Pulsar VZ-R (SR16VE FWD, with Viscous LSD):
1st: 3,3333
2d: 1,955
3d: 1,333
4th: 0,975
5th: 0,756
final drive: ab. 4,4
My current setup for my NX2000, Euro P10 2WD / JDM P11 4WD combo:
1st: 3,0625
2d: 1,8261
3d: 1,2857
4th: 0,9268
5th: 0,75
final drive: 4,1765
Empire-CAT Machinery Tech
kind wierd, my b13 at 4000rpm im at 80mph at 5th gear, and my 93 ga16de is around 3400ish at 80mph.. is there something wrong here?
Project Achilles
I don't want to sound like a newb here, but i've been searching and i can't seem to find the answer to my question.
I blew my old b13 lsd tranny and got a p10 non-lsd tranny to replace it due to availability. i still have the old b13 tranny and i want the lsd back. i hate not having lsd. it's a major pita, especially in the snow.
what can i do to use the lsd in my old tranny? should i just swap over the p10 gear stacks to the b13 or the driverside case and lsd to the p10?
i'm not sure if there's a difference in the bell housing between the two, and i don't want to tear them both apart to find i wasted my time since it is my only car. any help is greatly appreciated. thanks, guys.
Parting out my car
Some GA16DE data to add to the mix
USDM GA16DE B13 FWD gearset:
1st: 3.3333
2nd: 1.955
3rd: 1.286
4th: 0.926
5th: 0.733
final drive: 3.895 (Sentra)
final drive: 4.471 (NX1600)
JDM GA16DE FWD gearset:
1st: 3.063
2nd: 1.826
3rd: 1.286
4th: 0.975
5th: 0.810
final drive: 4.167
On nissanforums they said apparently that JDM N13 and N14 have same final drive as NX1600, 4.471, but the N13 gearbox won't fit on our cars (you could still take the final drive gear to use in another box though).
For better low-end acceleration (from a stop, or hammering out of corners), which of the setups as-is would be best? I have the USDM GA tranny now, and I find it less than ideal, though fuel-efficient. Which one, an NX1600 or a JDM tranny, would be better? I dont care about top speed.
Discussion Starter #17
What blew on the b13??
I would swap the b13 lsd case and final drive over to the p10 transmission. you can only do this if the final drive ratios are the same. So p10 transmission have different final drives then b13s
Those aren't right according to my b13. I've checked mine with gps and it's accurate. I'm doing aobut 80 at 4000rpm in 5th. 3200 is 65. I would have been pulled over a whole lot if that thing was right. Maybe it's tires? I don't know the circumferance of a 205/50/15....
1 - 20 of 26 Posts
