Ok guys, what are the cheapest or free-est mods for an NX2000? Any reccomendations for my broke ass?
I would use a Zip Tie instead of bailing wire. BTW,this "GHETTO" mod makes as much HP(As proven at a SoCalSERCA Dyno Day earlier this year!) as a POP Charger for a lot less $$$$!First thing to do: go get yourself some bailing/chicken wire. Remove the bottom of your airbox. Rotate the top 180 degrees so the air filter points upward. Wire the filter to the box. Whalla. Instead intake!
This is what they're talking about.go get you a cheap breather filter(2 bucks) to take off the aiv hose. <snip> its a simple breather filter for like a v8 from auto zone.
And here's a link that will show how to do that.Also bump your timing to 17 degrees for 87 octane or 19 degrees with 92. Good for a few ponies as well.
Here's a link that will explain just how to do it.For a "feel" of better throttle response, make your throttle cable just tight enough not to move the throttle arm(?) off of it's stop.
And the link for that:Clean your TB really good,
www.sr20de.net/engine/change_oil.htmlfreshen up the car about every 3 months with an oil change it helps
www.Jimwolftechnology.com has an ECU program that will allow you to remove the AIV and still have a clean burning motor.I eliminated my aiv altogether.
You'll notice a growl sound coming from the intake. Especially at WOT. But it's not annoying.How noisy does this mod make the car?
Mike Kojima recently test drove one,and he liked it so much,that he couldn't decide which motor he liked better,a stock SR20DE or a stock QG18DE.Better than the GA16DE?
