Well after long searching on the net i have found a cheap way to run a MAP sensor for the EMANAGE with out getting the GREEDY Map sensor. Here it is
That is the 2 bar map sensor with connector that you can order from www.GMPARTSDIRECT.com the Part numbers are GM - 12569241 and 15305891 or AC Delco Part numbers 213-1520 and PT1035. and heres how to hook them up
For the connector to plug into the Emanage I will be using the Internal CD Drive Audio Cable. Ill let you know how it all goes. Just figured that i would share the knowledge. I found this on the Miata Foums http://forums.miataturbo.net/printthread.php?t=485&page=2&pp=10
