1 - 19 of 19 Posts
so.. after a long time of tryin to get the damn starter off, finally got it and i realize they sent me the wrong starter!
my original starter is the long one on the right... i dont know what car this other one is for?
at that point i called it quits and went in (started getting dark anyway)
is it possible to some how switch the end from the old one to the new and make it work? frustrating.
took a week for it to get here... so now maybe another week of walking around the lot at school asking people to help me push my car to get it started.. lol
im gonna call tomorrow to see if i can get the right one sent or something.
Don't despair. Yet.
Your original starter, on the right, is the Mitsubishi and the other is the Hitachi. They both should fit even though they look different.
Give it a try!
Bill Conner
<>< Jesus is the Answer
billc said:
Don't despair. Yet.
Give it a try!
Bill Conner
exactly...the shape is the same if you look closer at it you will see that they will both fit in the hole. Throw the new one in and be amazed at how much more quiet it is when you start your car.
oh really guys? yeah, i wanted to give it a try because the shape looked the same... but the lil gear head things had a different amount of of things on em and looked a lil different, like one had 8 and mind had 9 (i think) so i didnt think it'd work...
But i might as well try it huh?
Oh by the way i just looked at them and they both said Mitsubishi on them, the new one didnt say Hitachi. :confused:
thanks
I was swapping trannies between my dads SE-L and my 200sx and noticed his starter looked like the one on the right on your picture and my starter looked like the one on the left. Both work fine.
alright, well GOOD to know. I'm going to give it a try today. :)
thanks for the replies guys.
You wont run into any issues. I did this only a month ago and had ZERO fitment issues.
SE-R Mana
This is good info. I need to change the starter on one of my SE-Rs and have been holding back due to a few reasons: difficulty at accessing the starter location; still trying to find the receipt of a Bosche starter that my brother put in (supposed lifetime warranty); lack of free time.
as long as the bolt patteren is the same, and the connectors are the same, you should have not problem installing it. i've changed my fair share of starters. they've had shrouds, without shrouds and once i got a starter with a noticably smaller motor assembly, must have been from a newer sr20, i dont know, but i've killed it already. it seems that starters hate me. i've killed so many and i hate changing them out.
Ae you having someone help you install this?
If not, it gets a lil tricky but it can be done alone.
FUN FUN.
Discussion Starter · #12 ·
yeah i had someone help me out. I got the new one in today and was about to finish puttin everything back together so i could try and start her up... but it started to rain a lil so we went inside. :( hopefully i'll check it out later on today
Big Juice & Big Boost
DOn't worry the one on the left is gonna work on your car. The only different is the left one is for automatic and right is manual. I just install the same starter u got on the left. You just have to extend a wire on it.
Discussion Starter · #16 ·
yeah, i extended the wire on it like a foot almost and it worked out fine. :)
and thanks, i was wondering why they were different.
I thought my car liked to eat starters too. Turned out it was just an intermittent ground problem. The factory ground sucks. I now have a wire running from the starter bolt to the chassis.
interesting, i might have to try that too...
well if mine poopes out again ill replace the wire...im not diving under that car unless i have to. Its allready enough of a PITA to get to as is.
1 - 19 of 19 Posts
