Does the GTI-R intake manifold have interference problems with the firewall on a NX2000. Do you need inserts or new "solid" mounts. Is there a problem with the torqueing of the motor and the manifold hitting the firewall. TIA Chris
Jah Rastafari
There is no clearance problems with the NX2000. Get the mounts that will suit your need they will both work. No te manifold will not hit the firewall under power.
Andreas have you ever dealt with a comany called Kanjimoto? They're based out of Fort Lauderdale. Also, do you do business with Isidiro?
