Hey I'm pretty new here an after any information and advice.
I have a 1991 N14 GTI with a mighty SR18DE.
I also have the factory electronic triple gauge from a GTIR (oil temp, pressure and boost).
Firstly has anyone been able to get oil temp and pressure working on an SR20DE and is it possible for sr18de?
Any help Is appreciated
Stop Lying Or youll lose
should be the same signal wires unless they change. Like for boost gauge is it electronic? might have a sender that reads vacuum/boost, for oil pressure and temp if possible reuse those fittings on the sr20de block if they fit?
I hope its the same signal wires, however because they were never set up with a sr18de i dont know where a signal for temp and pressure could come from. All gauges including boost are electronic.
