What kinda power are guys putting down with GTi-R motors on stock injectors and turbo also what is the max boost the stock T-28 can handle and lastley the most horsepower the stock injectors can make???
With stock turbo, internals, injectors, ecu, full 3" exhaust, got us 282whp/271tq @ 15lbs. With forged pistons, 555cc injectors, S15 T28, full 3" exhaust, e-manage (base tuned) it put down 297whp/316tq @ 15lbs (falling off to 13).Nizmonik SE-R said:Mario, SR20 B12, I think he should chime in soon. They Produced 300+ WHP on stock injectors and Turbo on a B13, I forget what other mods they had but definately a Turbo-Back and FMIC. They've got Dyno Sheets to prove it too!
Allan
If the engine and turbo is in good condition, you can run 15psi daily. You will wear out the turbo before you harm the engine.pimpride said:Is it safe to run 15psi only when I race??
250 tq. after that you will break the trans 3rd gear. My first went at 269 tq.2slow4u said:How much boost and WHP can the GTIR put down w/ the B14 tranny?
Get a B15/ P11 trans and dont worry about it. I was doing 20psi daily which was 440-450whp without problems.2slow4u said:How much boost and WHP can the GTIR put down w/ the B14 tranny?
Our buddy Oscar made 303whp & 293tq at 15psi on 370ccxher0 said:is that for the actually gti-r engine, what about on sr20de engines with the gti-r setup installed? what numbers are they looking at then?
