easy 400WHP
remove the visible 10mm bolt, then just yank on the other end....make sure somethign is supporting the hatch *** its heavy...
B13 Switch Hitter
93 maybe different........ remove the 2 bottom bolts. tried yanking the strut out of the top with no luck, BUT... you can loosen the the part attached to the hatch and unscrew the whole thing out..
Ya I got it out but the replacement ones I got dont fit anyways so its all good. Can the stock struts be "recharged" though?
