1 - 19 of 19 Posts
easy 400WHP
i think i will use it even on my LSD tranny...as opposed to buying a 700-800$ NISMO LSD Unit... brothas be broke these days so a $250 PG that is said to perform pretty good and while aiding a stock LSD may be a good option for me
I believe the part number for any thing with an SR20 is 906-GOLD
and if you wnat the heavy duty app its 906-Green (stronger springs)
there was a group buy onit some time ago that got it for like $230...maybe we can run another.. Id be down!!
I installed one on my non-lsd tranny. I used the upgraded green springs. I like it but it didn't perform as well as I would like. However I used only 1 spacer because i had a weak c-clamp. If you put 4 spacers, I guess it would be much stronger.
Well at least the inner wheel doesn't spin like crazy when I accelerate out of a tight turn like it used to on an open diff. Seems to launch a bit harder without spinning. The only "real" lsd I driven are rear wheel drives so I can't really compare.
Road Race DE
I have one installed in my 98' non-LSD tranny with the green springs and the max amount of shims that would fit. I am very happy with it. Powering out of a turn no longer results in the inside tire lighting up. It works in a very linear manner and I also have no problems with torque steer. I think it is a great alternative to a gear or clutch-pack based LSD.
todd, who did your install?
could you mention his location, price, and how much it cost you total. just pm me if you can't mention it here. where in sd are you at? are you the green se?
Just do the install yourself.. I did mine and that was the first time I opened the transmission. It is very easy if you don't disassemble all the gears like I did.
They're just cones!
I really want to try one, but I'm afraid the semi-locking will increase push in slower, autocross type corners. Any opinions on this?
1 - 19 of 19 Posts
