1 - 9 of 9 Posts
well jus found out i had 2 bad valves ..and was wondering how would i go about rerbuilding it the motor it gonna be sprayed then turbo down the line i was thinkin bc stg 3 cams springs/retainers/valves/lifters/rockers/.port and polish head port out manifold,throttle body out get bigger,angled valve job depending on how much..sounds good forgettin anything i wanna do it right so there no worries ohh and it gonna 100shot direct port then progessive soon after
You trying to copy me??? Just kidding.
is there any power gains when porting out manifold/throttle body....??also are vg30dett injectors 2 big for a nitrous/all motor setup???:confused: :confused:
Done.
Porting and polishing can allow for better gains, as it helps with flow characteristics. I wouldn't just do the intake side of the house though, I'd do the head as a whole. Also, why port the throttle body? Just go with a different TB and get a JWT or Calum ECU. JWT has a nitrous program, IIRC. Doesn't matter what injector size you go, they're still going to flow at the stock FPR settings, unless you get an AFPR and a fuel pump that will support higher flow rates.
ok so is there anything in particular i should do like machining wise???jus do the whole and replace everything....the tuning part im leave that up 2 my boy cuz he doin it 4 free do 2 the fact of me being the first nissan he does all the other cars he's done came pretty good..(honda/mazda/toyota):biggthump :biggthump :biggthump
that will be about 12.5:1 compression or so, maybe 12.8:1.
with those cams, i dont think i'd mill the head, your comp may be too high and you may have detonation issues.
so what do u suggest i want a all motor beast wit some juice jus i case :biggthump :biggthump
Why not have someone build you a head, who knows the entire situation your motor is currently able to withstand? You can spend 3g's getting a head to flow and it's worth it, (When it doesn't blow up, cuz of mismatched parts).
1 - 9 of 9 Posts
