BTCC VE Power
i bought a sway bar and got no instructions...
I searched and found out that you need to drill out some holes in order to install the sway bar... you need to drill two new holes and enlargen two other holes...
the thing is i dont know which ones to drill out...
there are two sets of holes already there do i drill out the front or the rear ones? also which way does the bar face? [ or ] when facing the rear of the car? i assumes its the first position....
TIA
There are 2 square nuts welded to the inside of the side arms, near the beam. If you have ABS, the sensor wires are bolted here. Those are the rear holes. I just drilled through the side arms, from the outside, and that knocked the nuts off. Do that on both sides, and then lift the bar into place. You will need to drill the front holes from the inside out.
