3 wheelin'
I have read numerous posts here and can't make heads or tails if I have abs or not. I know I can look at the axles and look for the sensor but don't have access to the car right now. I looked at the engine bay last and saw a fuse relay for the abs in there but I didn't see an actual abs unit in the passengerside of the engine bay. Nor did I see a control module on the passenger side floor board. Someone help me out please as I am about to order pads and rotors.
I also heard that all the 91 Japan made NX2000's came with abs. True? False?
Does it matter if I order ABS pads or rotors?
merely a flesh wound
If you have ABS, the hard lines from the Master Cylinder will run over to the passenger side of the engine bay, into the ABS unit
False
No - HOWEVER, the parts books are all screwed up. Make sure when ordering pads and rotors, that it's for a Japanese made NX (I know, I know, they were all made in Japan, but this will assure you get the right stuff), with 257mm rotors. That's all you need to specify.
allmotorKA24DE
yeah, when i first got my NX, i was really unsure as to if i did have abs or not....but since then, ive definately locked them up on sveral occasions.
3 wheelin'
A VERY BIG THANKS Chris! :D It's much appreciated. I'm a noob to the Nissans. So I'll have more questions that I hope people can answer. Searching here kinda sucks cause there is a lot of false info out there. Is there a way for the mods to edit them out?
