Hey guys, I think I just broke the transmission on my Nx. I had a brand new clutch put in 500miles ago(I'm not too sure if the shop did a good job)but the other day as I was driving on 3rd gear, I heard something snap and my shift lever came all the way back to where 4th gear would be eventhough I was in neutral. Now I can bearly get the car on 2nd and neutral but none of the other gears can be engaged. Do you guys think it could be a bad clutch job(bear in mind that there is no pedal feel difference)or a broken linkage or some other shaft in the gearbox.
· wants to go play
Does the shift knob wobble all over the place like it's not connected?
I just figured out that 2 of the bolts on the tranny case broke off and the tranny dropped by an inch. but the tricky part now is that the both sides of the bolts go inside the tranny and seems like the only way to put it back is by unbolting everything else and put those 2 bolts on before everything else. If you know any easier way, please let me know. Thanks
