Ok, well Im getting my new headlights tomarrow, i have a friend that works at a dealership so im getting the pair for $218. Mine were shot out by a bb gun and are yellow and nasty, part of the reason i got the car so cheap. well Ive never installed headlights before, just bulbs, what are the steps i need to take to get them in there and even? I really dont want to pay the dealership to do them, I dont have much cash after the the new engine and clutch, im basically tapped, especially after getting the damn headlights, and im gonna have to go pick up a set of nokya's too!
Any help is appreciated guys.
I belive you will have to pull the front end off.
First the bottom air-dam then the front end
unplug the lights
after that you should be able to pull the lights easy
just a couple of bolts.
Should be pretty easy
I have my front end off right now
when i get home ill look and see
and take a few pics for you ill send
them to you tommorow if you want.
latez
Discussion Starter #3
hey, that would be great, thanks.
first the two bolts with the green circles
these two are inside the engine compartment
This is another view from above.
After you remove the green circle bolts the light should come out.
then remove the blue circle bracket and install it on the new light
putting them back in should be in reverse.
It will take some time to get the front cover off there quite a few
nuts to remove.
Hope this helps.
Discussion Starter #5
Uh, im didnt even try that!! I took it to a shop and forked out the dough, looks great now.
