not recomended cuz of heat soak from the valve cover most people relocate it to the front of car.or use a hood scoop
how much more work/ money is it to relocate it to the frontWhitelightening said:not recomended cuz of heat soak from the valve cover most people relocate it to the front of car.or use a hood scoop
well not that I am on a tight budget it, but if I like it how it was I would just have to get a hood with a scoop right, and it not then get it mount on the front, and what is a FMICSR20 in the 200 said:if you are on a tight budget, check out how serban did his.
http://www.sr20forum.com/showthread.php?t=68023
FMIC = front mounted intercoolerthehammer said:well not that I am on a tight budget it, but if I like it how it was I would just have to get a hood with a scoop right, and it not then get it mount on the front, and what is a FMIC
3SE-Rawkus said:FMIC = front mounted intercooler
Manny
TREYDEE said:I say it depends on what type of motor you are runnin a TMI on.If you
are runnin a DET you should be okay to run a TMI but I recommend you upgrade to FMI later.If you have a Blue Bird set up on a DE its not safe to run the TMI cause the comp of the motor is to high and runnin the TMI is basically the same as runnin without an intercooler at all.You are prone to detonate, unless you add a hood scoop,don't do it be safe.
Yeah they do sell the hotshot kit. I think it comes with a greddy or hks IC. It comes with there t25 kit too.spdracerUT said:JGY offers front mount kits. I think they sell the Hotshot kit.
sr20deboston said:The Hotshot kit has a good-size Spearco bar-and-plate.
nizzan4u2nv said:Yeah they do sell the hotshot kit. I think it comes with a greddy or hks IC. It comes with there t25 kit too.
nizzan4u2nv said:The t25 kit is good for approx. 220hp depending on boost level and supporting mods. Its a full bolt on kit, a good idea if your motor is still good.
