Got a red top Sr20det t28 turbo cams 1050cc injectors new fuel pump fuel filter and coil packs fuel pressure to the fuel rail with line hooked up is reading 38 car is tuned on E85 afrs are reading high 15 to 16 at idle if I Manuel tighten the line for more fuel pressure to 40 they come down but gets chocked out under load if I go wide open throttle at 40psi on fuel rail about 12.5 afr in boost should I be worried about high 15 to 16s at idle
