1 - 16 of 16 Posts
· Premium Member
Yes it will. All '91'-'99 SR20 blocks are the same.
EDIT
All SR20DE blocks are the same.
[This message has been edited by eric96ser (edited 10-10-2001).]
hey man hows it.
have you got all the manifolds and stuff as well to go with the head? why not do some work to your current head? get it opened up a little and freshened up. nothing wrong with the low port head.
chris.
primeras its where its at.
· Premium Member
Thanks for all the responses guys, I appreciate it. The reason that i'm using a high port head is because i want to leave my lowport head untouched in case something goes wrong.One more question, would i have to change the intake manifold, or would the lowport intake manifold fit the high port head? Thanks again guys.
Jorge
'96 SE-R
Speaking of manifolds Greg.......
MUAHAHAHAHAHA
COME ON GIVE IT TO ME!!!!
Above quote from Horace Pinker in the movie Shocker.
95 200SX SE-R--> Hot Shot CAI, Custom Apexi Cat Back, ST Shifter & G4 Hotshot Headers, Viteks and Iridium, B&G springs, 91 Cams, NOS 50 Shot, 17" Konig Tantrums wrapped in Nitto's, a bunch of stiffening and look good crap, JWT CPU COMING SOON!
<font face="Verdana, Arial" size="2">Originally posted by JRios:
But, wouldn't I be able to just install my lowport intake manifold into the high port head? TIA
No. I asked this question on the list a long time ago just out of curiosity, and I was told it doesn't work that way.
· Veritas
Um, Project SE-R;
Isn't this a topic you will be GREATLY interested in, regardless?
You know you want what I've got. Yeah, it's bare and will need some work....but it would kick ass on your '95.
I forgot to mention....I do have another highport intake manifold....it's been drilled/tapped for direct port nitrous use, but the holes are a little bit too close to the fuel rail. I could plug 'em up with JB Weld, though. You'd never know....
Come to the highport Dark Side, my friend.....
· Premium Member
Discussion Starter · #11 ·
Damn it!! So what else would i need to do this swap? Thanks for all the help guys, I really appreciate it.
Jorge
'96 SE-R
HEY SERprise! Tell me how utilizing the highport head and intake manifold would be better. IM not being a smartass here, I really dont know, honest!
Is that other intake the JDM like the other or US?
Oh yeah, ow much work would need to be done to the head? I was going to have it machined and planed(sp?) and a little angle valve job done on it. HELP ME YODA!
· Veritas
John and JRios;
From where I sit, you'd need a highport cylinder head (duh) and a highport intake manifold (both upper and lower sections). Your throttle body would be moved, but not too much.
John;
My JDM will stay with the turbo (IF and WHEN it arrives, that is). The US one can be plugged up and will be ready to go. Don't ask me how I know if JB Weld works like this...
The cylinder head I have is completely bare, and would need the treatment you mentioned above, plus transfer of all valves, retainers, springs, etc. It is completely bare.
(Edit) Of course, you both will have to consider the OBD1 vs. OBD2 questions, and problems (read: check engine lights) that this might trigger in your cars. I *think* 1995 cars were the last year of OBD1, but I could be wrong. 1996 is definitely a OBD2 car, and this swap might set off check engine lights/codes from here til Sunday, for all I know. (/Edit)
[This message has been edited by SERprise In WV (edited 10-12-2001).]
In order to swap a high port head into a 200SX, you will need the following:
1. high port throttle cable
2. high port cruise control cable/unit
3. high port PCV hose
4. high port intake manifold and throttle body, complete with all hoses and throttle cable bracket
5. support bracket from block to intake manifold
6. high port intake tube from MAF to throttle body
7. high port power steering pump (or just the elbow that leads to the fluod reservoir)
That is about it.
Good luck,
Jay Whitely
Tampa, FL
1996 200SX SE-R
GTi-R powered with F-MAX kit
· Veritas
Well, guys, that about kills that idea, I guess. Too much stuff, IMHO.
Thanks for detailing it, Jay.
I had a rough idea of what was involved with lowport engines, but am stuck in HighPort Land, and I like it.
· Premium Member
Discussion Starter · #16 ·
Thanks for all the help guys, I appreciate it. Guess I'll just stay with my lowport head, it's to much trouble, not worth the hassle for me. Anybody have a lowport head that there willing to sell? The reason I wanted to know if it would work was because I wanted to do some work on the high port head and I didn't want to use the original head so that I could keep it stock and put it back on the car in case that something happened. But anyways, thanks again guys.
Jorge
'96 SE-R
1 - 16 of 16 Posts
