I am selling my current turbo setup since i have since upgraded. I would like to sell evrything except the ecu and injectors as a complete kit but will part out if there is no movement as a full kit. I will try to get pics up asap. fell free to pm me with questions.
1: hks gt3037 turbo 52t .73ar exhaust side .60ar comp side with teh garrett gt30 compressor housing. has about 7k miles on it and is in good shape with no unusual shaft play. I did have to sand down i little of the comp housing to get it to clear the block but nothing major at all. I also had the piece of charge pipe welded to the compressor as i had a continuess problem of blowing it off. The pipe is 2 inch diamiter and about 10 inches long and will work perfect for anyone else who is running a fwd sr20 setup. Turbo is capable of 400+hp and is vertually lag free. You can actually hear the turbo spinning for a full 30-45 seconds after you shut the car off. I will also include the oil and water lines which are in decent shape
2: gtir manifold flanged by ANDRIS for 40mm tial external wastegate. manifold looks brand new and i do not think you will find a better externally flanged gtir mani anywhere.
3: custom made 3 inch stainless steel maderal bent dp. This dp is made specificaly to fit this turbo kit. it has the dumptube for the wastegate welded into it and has 2 o2 bungs. 1 for you normal o2 sensor the other is great for a wideband or whatever else. It also has an exhaust cutout welded in for track days so you can run open dp. Cutout comes with the blockoff plate and new gasket.
I would like to get $1000 plus shipping for these items which i feel is a very fair deal. I am however willing to negotiate
4: Jwt ecu 50lb 3 bar cobra maf program for 95-97 ser w/ manual trans and 8.5:1 comp. $400 shipped- SOLD
5: 4 msd 50lb injectors in good shape. $150 shipped
Pics are located mid way down the page!!!!!!!!!!!!!!!!!!!!!!!!!! thanks
