How? 200sx Dash Removal
1936 Views 4 Replies 4 Participants Last post by  98SERwTricks
i'm pretty sure someone has done this before. Any Advice on removing the dash, particularly on a 98. I've attempted this before, but couldn't figure it out. Is it pressed in, should i just pry it out once i get whatever bolts and screws out? thanks!
uh, which part of the dash?
coverings, primarily top portion, and piece in front of the passenger (above glovebox).
Its all one piece (that top part)...
You'll need to remove the passenger air bag, glove box, center console and radio trim, there are bolts towards the bottom below the radio, some under the dash near the glove box and drivers fuse panel, two on top of the dash, remove the insterment cluster some behind there
Then you'll need to either remove the steering wheel, or drop the column to make room....
That about covers it.
Chris
Chris
Damn - I guess I'm not dynamatting my firewall anytime soon :tongue:
