i was wondering if there is a way you can tell if your injectors are maxed out by voltage from the ecu pinouts or anything like that. Besides the obvious that your detonating at higher boost. Reason i ask is that i'm running the 3 bar program with 370s on a t25 with s3 cams on a stock maf. If i run under 10 psi will i max out the injectors and/or the MAF.Any input would be greatly appreciate. Thanks!
