keep the sensors. the car is made that way. think of it. unless you're a electro mechanical engineer. the sensors are there for a reason and the ride whips better with them on. but hey you can be a guinea pig and try it first then tell us what you think bro.
I called the Nissan dealer and the service guy said it should go off after 20 starts.
4 starts later -walaaa!!- the light is out!!
thanks for the advice though fellas!!!
"Spidey"
3x ex-Honda owner
after the problem is fixed, take the pos. battery terminal off the batt. for about 2 hours then hook it up again and you should be back to norm.
O kay so I was wondering how the car would run without the o2 sensor hooked up and now my check engine light is on...DOE!!!....
How can i reset this thing? It totally spoils my dash's shiny armorall finish.
"Spidey"
3x ex-Honda owner
