1 - 19 of 19 Posts
I have a gtir kit im puting on and wanted to know how to wire up the injectors, I already have resistor and the gtir rail. Also which is better to use the gtir or the stock one?
I <3 MILFS
you need a different rail thats for sure, but I dont know if the GTi-R Rail will work on a SR20DE. I may be wrong though, you can't use the stock rail though because thats for sidemount injectors, and the 444cc's are topfed. So what I did was I just bought a new rail from JGY for topfed injectors.
Wire the resistors into the the injector signal wires by the ECU, that way your engine bay will look better that way.
I have a jgy rail but its too big for the 444cc's and where do I wire the resistors I dont understand where you mean.....
the injectors are too small to fit in the jgy fuel rail its made for 50lb and 72lb msd
lemme ask this, will the 444cc need resistors? I am looking to get a set w/rail and need to know. Also do they fit fine on the intake? And I imagine I would need the clips.
This is one of those hard to search subjects, has been asked many times and there's no sticky for it :/
yes they will because they are low impedance. the car will run without them but will run very rich. u need four 6.8ohm 10watt resistors. you put them on them on the signal wire for the injectors u can also put it on the power side if u want.
thanks alot fellers for the quick response. I have been trying to edumicate myself on the subject. I know the basics of Turbo, is the other stuff that is getting me, lol.
Hopefully, I will be done by the end of the year.
Discussion Starter · #11 ·
How do Know which wires are the injector wires that go to the ecu? And will the stock injectors wire conectors/clips work on the 444cc injectors?
Discussion Starter · #12 ·
any help with this?
Discussion Starter · #13 ·
ttt .......
Discussion Starter · #14 ·
any information given is grealty appreciated.
Discussion Starter · #15 ·
ttttttttttttttttttttttttttttttt
Discussion Starter · #16 ·
Aight I spoke to someone and found out that you wire the resisitors into the negative injector wires. I have the gtir clips for the gtir injectors and they all have different colored wires but all 4 clips have one thick wire and one skinny wire. Which one is the negative wire?
Discussion Starter · #17 ·
Aight I figured out that the skinny wire is the ground for each injector set.
FWD PWNAGE IS HERE!
Just solder the resistors inline to the negative wire on the injectors. JWT had a write up on how to do this properly and I used it for my gti-r injector install but I can't find it so here are some of my install pix..
Discussion Starter · #19 ·
Hey Thanx for your help I grealty appreciate it and the pix are a big help too.
1 - 19 of 19 Posts
