www.motorists.org
I plan on getting the autometer $35 white faced one. How much of a pain is it to install? There's wiriing it to the dimmer switch, probably routing a vacuum hose thru the firewall, etc. How long does it take and how much of a pain is it?
And what does is measure? manifold pressure? Intake presure before the TB?
_______
I have mine t'd into the vacume source for the WG. I also have the boost controler signal t'd off of the same thing. I'm planing on using the vacume bung that is rite under the TB for the guage. On the 98's its not used and should work perfect for reading boost *and* vacume. The wiring is simple I'll take a look at it later and let you know exactly where the wires go.
Mike
www.motorists.org
It's getting VERY close to time for me to get one of those. Got that wiring Mike?
_______
One wire hooks up to the red and yellow and one wire hooks up to the red and white. Just shove the wires into the conector and see witch combo works rite when you dim the switch.
Mike
