Seeing that my motor and mind are operating once again, I had a crazy idea! I bought a set of 72lb MSD injectors (50lb unit for sale!) for the engine build up. Now that the motor checks out OK, I am thinking of installing them along with the 4 bar ECU program and a Stage 5 turbo. I will also purchase a set of cams and cam gears. I want to see if 420-440+ whp is attainable along with my existing Stage II manifold. Mind you, my block is completely stock. The reasoning behind this is that precise fuel metering and timing can create major HP. Detonation shouldn't be a problem. Am I crazy or do I have a valid point?
321.2 HP @ 6500 RPM
285.1 ft/lb @ 5300 RPM
3 bar Program w/50lb injectors...TO4E/T3 Stage II
12.81 @ 116.8 mph
321.2 HP @ 6500 RPM
12.81 @ 116.8 mph
