Can you run on GTiR T28, 370 injectors @ 3 bar and stock maf?
97SE-R C2 said:9-10psi
Soopastank said:In my car, anything above 9psi on 91 octane pings. I've hit 10-11 psi with race gas and the car ran just find. I'm sure I could've squeezed out a couple more psi but my maf (stock) and injectors (370's) were pretty much maxed. For a track (1/4) run I think it would've been okay. If your looking I have a T28, 370's in fuel rail for sale.
Sure was, just re-read the article. He ran 13.25 @ 103 9.75lbs boost on 3 bar. So I will stick with 10 for the time being.97SE-R C2 said:Greg was on the 4 bar fuel system on that run and I can't remember if he had the S3's in yet or not.
I run 12 daily on the BB setup and have run 14-15 @ the track without any problems on 93 octane. Although the turbo looses its effeciency after 14lbs.TREYDEE said:How much octane is considered race gas,I run 93 octane daily I should be able to run 14 psi safely here and there right????
I'm not sure if my motor is 10:1 or 9:5:1 but that should'nt matter rightI run 12 daily on the BB setup and have run 14-15 @ the track without any problems on 93 octane. Although the turbo looses its effeciency after 14lbs.
Yes it will matter. My motor is 8:5.1. Higher the compression, the greater the possiblity of detonation!!TREYDEE said:I'm not sure if my motor is 10:1 or 9:5:1 but that should'nt matter right
