1 - 13 of 13 Posts
notnser racing
Well for all of you who are currently racing, I have been using camber lugs nuts in all of the shocks of the car but I will like to have more adjustability in front so can you guys recommend me a good set of camber plates for a b13.
employment whiplash, NC
Only 2 I know of are Ground Control and Cusco/$tealin. Both require coilover systems. I've had both, Ground Control plates are far, far superior in every way. Expensive? You bet. And rightfully so.
wants to go play
mpg9999 said:
Ground Control.
+1.
The cusco/$tealin ones are nowhere near as nice.
Take the camber bolts out, they slip when you run sticky tires.
Drinking The H Juice Now
not if you tack weld the strut ears to the knuckle.... ;) ask me how i know this... :tongue:
Or you could always slot the struts, align as desired, using fender washers on the strut bolts, then weld the washers to the strut ears. A little easier to remove the strut later that way. Not that I ever did this.
notnser racing
Discussion Starter #11
Tell me about it, I still remember 4 months ago when my camber rear lugs didn’t hold to my kuhmos and there went the nice color of my brand new AGX all I saw was a big black flag and a bunch of smoke.
We just redrilled the 3 holes in the top of the tower, not exactly adjustable but it worked, and won't slip.
Without a doubt the best way is what the Silkroad suspension does for the S13/14. They have a square metal piece with a hole offset. Then two knobs on each side of a elongated hole. Depending which way you turn the offset metal plate you get a different amount of camber. 4 adjustments no slipping. Add that with the top camber plates and its unreal the adjustability.
1 - 13 of 13 Posts
