Alright everyone, this is my first large write-up so bear with me.
I bought AGXs with GCs a couple weeks ago so I could have a set of dummy suspension to tool around with, just to get to know the ins and outs of suspension.
I had heard (in shortened Koni threads) that you could modify the lower spring perch to better accomodate a ground control coilover sleeve, and give more room for a wider tire. I couldn't figure out for the life of me what people were talking about, so I figured I would give it a go.
I can tell you right now that as soon as you are holding a strut housing in your hand with a ground control coilover kit installed, it is very obvious what the modification is. That being said, I felt that I should give back to this wonderful community with my own write up on how I personally went about doing this.
Enjoy.
We begin. There she is, the lone strut with the sleeve. You see that ugly useless lower spring perch? That's our target.
Make your marks with a sharpies so you have some sort of guide. I eyeballed all my other ones, I just wanted to show you guys where I'm cutting.
Dremel action shot! I love the new quick release cutting disks.
Make three straight cuts first, and then get the corners after the perch is gone.
Cut the other side so that it is loose and jingle jangling.
Two more cuts to give ourselves enough room to slide that mofo off.
There it is! Our lower perch has been removed.
Side view BEFORE I go cut the corners off.
Corners cut.
Whip out your trusty wham-wham.
We shall wham wham right here until the remaining tabs grip the sleeve slightly. I would SKIP THIS if you ever plan to remove the sleeve. But if you've come this far, why not? You are only going to be using ground control sleeves on this strut for the rest of it's life anyway.
There it is. Lower perch done. If you are doing work on your fronts, you have finished.
I was doing my rears and I decide that I didn't want the upper perch either. Your choice, it doesn't really do anything. I just figured I'd get it while I had everything apart. Plus I have like three extra sets of these rear upper perches anyway.
There she is!
My vise doesn't open enough to hold the whole thing, so this is what I did to hold it in place while I did my worst.
Snip snip!
Smoothe out the rough edges with a sanding attatchment or a grinder. Your choice. I also opted to smack the fresh metal with the hammer a bit to round it out.
Side shot.
Before and after shot of the rears. We make sexy time, yes?
Il est fini!!
Enjoy.
Corners cut.
There she is!
Snip snip!
Side shot.
Il est fini!!
