41 - 55 of 55 Posts
yeah i tried it too and it didn't work for me ether and that's the same wire that stay tuned got and my ecu is for a bluebird i was hopeing for the best though :confused:
okay according to that diagram there are 4 cables right? 41,32,32,X so i removed the 2 cables that says 32 and it work and i have b13 with 1.6 liter and auto but now the a/c doesnt work. do i have to remove just 1 cable? and which one is it?
... like as in rice
I just realized that I cut the wire n the opposite end because I was looking at the ecu pinout as the connector pinout... so I'm going to try it the other way now lol.
does anybody have an idea how to fix or wtfk? happens to the speed sensor i have a 94 se-r blew 1,2,3,4 gears i changed the tranny and the speed sensor becuse the good 1 was cable but when i put it on the other 1 it stoped working **** have n idea i always had cable sensor thats y i asked
Drive it like ya stole it
Maybe if you spoke in a mannor that people could understand your question, you might get help. Also, start a new thread.:biggthump
Hello everyone!
Im new in this comunity!
I dont know if any of you will see or even answer to this with the facebook thing in 2021 .
But i have same question about the car speed signal and no answer .
I make lots of reseach about the famous signal that go to the computer For speed signal.
I thinking to cut some volt in this one with resistor .
My issue was because of the fluctuate values.
I run full sr20ve swap and computer . If i cut this wire,the first issue was vvl stop working and the low rpm moving down just little bit.
I not try to make speed like this.i just try in running condition /vvl activate ,im just disconnected the wire and vvl stay open,when I depress de gaz the engine stall.
I can see also the signal look like pulse with delay.
May be im wrong but i see volt change when car its slowly moving and make it s faster when accelerate.if im was in parking with car running and same time i connect/disconnect the wire 32 in the ecu,the motor stop.
I try to find something not expensive for control the issue.
I not find any answer about pulse control resistor..
I any of you can show me any trikkle.
I will be very happy.
Nx2000 from Québec.
Thanks.
41 - 55 of 55 Posts
