It pulls straight out. Check the FSM for instructions on removal/installation.
I can tell you from experience, you want to make SURE you put it back in correctly, had to go find another tranny after putting mine in wrong, it broke the keys off the oil pump.
Hit me up sometime if you need specifics, but once you unbolt the torque converter from the flexplate, separate the tranny from the block, you just grab and pull straight off, really simple.
Rob
