Yes, I am hoping to hit the 410-420 hp range on the car. I am pretty sure it can do it. I just need to do a little tuning and it should! I just sent my ecu out on Monday to get the Drag Launch Program; hopefully I will get kicked off the track(11 Second Pass! *Wink* *Wink*)on the first run! Maybe I can pull something better than a 2.1 60' time on slicks (Yeah! 12.7 @112)!
Louis Anaya 1992 Sentra SE-R
349.6 hp & 288.9 ft/lb @ 19 psi, 13.6 @ 111 mph(Street Tires),12.7 @ 112 mph(Slicks), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (7-9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Sumitomo 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24x8x13 Slicks(Drag)
