This is very frustrating. I just installed a set of S3's, and the idle is lopey as hell. I had a mishap with the chain tensioner, so I thought that maybe I skipped a tooth up top on the cams; nope, there's 20 links between the timing marks and they line up at 10 and 12.
So I tried andreas' trick; lined up 10 and 12 up top and try to look down below to see what the crank pulley said. It says aprox -5º from the -5º mark. So I look up top, it looks like it isn't quite at 12, so I put the crank at 0º and the exhaust cam dowel looks like its at 12 again.............ugh, I'm so frustrated. Why oh why is it low on power and lopey as a stroked 350?
On a side note, I ran last night at the track and ran a 16.4, then a 16.2. It seemed to fall on its face on high rpm's, I checked the timing and it was at somewhere around 25-30...so that would explain SOMETHING. Also, I can't get the idle to be consistant worth a ****. I need some help, I'm tired of taking the valve cover off and putting it back on in such a short period of time. PLEASE HELP!
