I thought all of this would end when i got rid of the 50LB 4 bar setup, but now the car is at it again. The car idles like complete **** when it is cold, anything below an indicated 180 on my temp guage and the car wants to die if i let it come down to idle. I am only reading about 10in/lbs of vacuum at "idle" which is usually around 800 rpm and is VERY rough. The care feels like it has a cam in it or something, and a huge one at that. I have done a pressure check on the entire system and there are no vacuum leaks so that is ruled out. I can not get the car into timing/base idle mode because of the horrible idle. Does anyone have any ideas as to what is going on here, because the car runs perfect except for this problem.
