1 - 20 of 63 Posts
easy 400WHP
So I yanked out the MSD Digital 6+. As much as Id hate to admit it and face all of the I told you so's. I hope that the stock ignition lets the car run way better (to a certain point, I'm sure)
Is there anything special about the stock components of the ignition?
Like the transistor and coil...do their cases need to be grounded/touching metal or can they be mounted anywhere.
I plan on doing some more wideband tuning this weekend and see how the car acts on stock spark.
Any tips or last minute checks/reminders?
Team Tool
Just want to let you know my car is running strong on the Crane ignition.:biggthump :biggthump
Just ask Powder :biggthump
I also have 534 miles on the clock now. Oil change and dyno coming soon.
PLAY MY HEAD, MONKEY!
From what i've seen, MSD Dig. 6 is fine with the B14's and the Crane ignition is good with both b13's and b14's?
easy 400WHP
yeah the rumor I have is anything externally coiled, be it B14 or B13, the MSD doesnt perform as advertised.
Again, I really hope thats the case.
Anybody know where to get a Crane DSR (p/n: 6000-6424) for under $300?
easy 400WHP
youre barely changing your oil??
I did it every 50 miles up to 100. And now every hundred up to 500. Then every 500 up to 1500. Then switching to synthetic and commencing regular cycles...
easy 400WHP
Oh and I forgot, so can anyone confirm if the Transistor & Coil need a chassis ground? I have mine mounted on the driver side frame rail and the coil is just Zip tied to a PCV hose LOL
The dig 6 only works well on the B14. I tired the 6A, 7A, Digital 7, Digital 6 on my can and none worked well. Lots of low speed transitional boost driveabilty issues. The MDS was causing spark scatter.
B14's don't seem to have the problem.
A Crane igntion seems to work great on my B13
easy 400WHP
Yeah Thats what I hear and remember you saying.
My main problems seem to be at full boost when the gate is open or when I floor it and it reaches full boost.
My plug gap is tiny and if I open it more the car will run like total ass. I feel as if the spark is too weak.
This weekend should tell all. I hope the Crane is the solution. Then I can finally move on with my project.
Team Tool
What do you cap and rotor look like?
70/30 Racing
I am pretty sure they all have their own grounds built into the harness.
Don't you have a multi-meter?
easy 400WHP
Discussion Starter · #12 · (Edited)
new....
word on the oil changes.
just cause I have a multimeter and can determine if the harness has a ground doesnt mean the case doesnt require a ground to prevent EMI...
you know EMI...the reason you get that whining sound on your car that increases w/ frequency as the engine revolves higher? :D
Team Tool
new....
Or the reason your car has a 5k redline when free-reving. EMI no good, just put a ground wire on everything.
easy 400WHP
Discussion Starter · #14 ·
no emi here, sir.. My edline is well in th 7ks :) found that out the scary way last time I was wideband tuning..watching the LM-1 instead of the tach LOL
70/30 Racing
Meh, my car will keep going to 8500 or so RPM, despite the rev limiter, in 2nd gear...
My SE-R has a really high pitched electronic sound, but it's independent of RPM. Oh well, probably just the sound of power... :D
easy 400WHP
Discussion Starter · #16 ·
Its official,
MSD Digital 6+ + Turbo B13 = My hairy Anoose
Im able to run a bigger gap and fire all the way through full boost/rpm without hiccups on stock ignition and 1 Bar.
Crane DSR on the way....
I wouldve got around to the wideband tuning, but my damn wideband bung plug stripped out.
Now im waiting on an M18 x 1.5 Tap before I can do anything else.
One step forward, 2 steps back...but somehow thats good :D
70/30 Racing
****, you had enough money for the Crane, but couldn't go to the convention?
Assface...
1 - 20 of 63 Posts
