im stupid please help me
ok i was drilling a hole over the radiator and i hit the wires that are over it. i taped the wires up. fixed some fuses that blew in the engine compartment and it still wouldn't start so then i replaced the relays in the car, it still wouldn't start. please help me what should i do!!!! it has to be something with the ingntion. thanks
its stock ;)
Get a wiring diagram, and find out what exactly that wire does, and check to see if you damaged any other wires.
little Thunder
Re: im stupid please help me
If you can please take a picture of the wires you damage and post it.
If anything you might have to cut the damage part and splice an inch or so of wire for replacement. Please make sure that you sodder the splice area and then tape it. Also verify the wire that you damage through FSM to have some knowledge of what you have damage for future referrence (just in case you have car trouble).
Sportbike fevah
If you need that part of the harness I have it intact
from my parts car strip-a-thon.
Peter
