Autohouse Import Factory
Having problems with my injectors. Heres the setup: T25, manifold, an 370CC injectors. Also got a Nismo regulator. Added a front mount and Super AFC(5 Knob) and the injectors keep dumping fuel into my cylinders. Its as if either the regulator or the AFC is causing the car to dump way to much fuel. I see many people running my setup on their DE's and never heard of this problem. I was running the fuel pressure at 40psi . What do you think would cause this?
Tired!
set your TPS and check O2 sensor and everything. ALso, take out the safc and see if it still happens. If it doesn't, then it is something with the SAFC.
Brent
Banned
boostenb13 said:
Solved problem, bought a Jim Wolf ECU....
Good to hear, I was gonna say to recheck your Fuel pressure, and make sure you set it with the vac line off, along with the stuff the Brent said. Where in FL are you located?
