without the clutch cable installed, how much play should be in the clutch release arm? i replaced the throwout bearing and axle seals while i had the tranny out over the weekend. i greased the input shaft and made sure the throwout clips were in place.every thing seems good. after i installed the tranny i noticed the slack. maybe 1 inch or so till it presses up to the pressure plate. i seem to forgot what it was like right after i removed the clutch cable.
is this slack ok? i would really love to take out the tranny. hopefully right after work. maybe i will work on it into the night with only a flashlight, no beer and lying in a puddle of tranny fluid. that would be so sweet.
Still not my president
a little bit of slack is normal, when the arm isnt attaced to the cable
