Fitting of the SR20DET is fairly straight forward as it bolts straight onto your FWD gearbox. Its sits in there same as the
DE so you can use your existing engine mounts.
The GTiR pulsar 170kw engine can be used although I hear that there's 2
bolts less holding the engine to the gearbox. Some worry and some
don't!
Its expensive to do but considered the ultimate conversion.
You will need the computer , loom and engine. Also perfoemance clutch
while you're at it.
Then install a new exhaust system from the turbo back
See the links for more info
check out (about sss pulsars but same as nx)
http://groups.yahoo.com/group/pulsarsss/messages
also check for info
http://laf.cioe.com/~benbobbo/cgi-bin/Ultimate.cgi?action=intro&BypassCookie=tru\
e
this is an idea of how it sits
http://groups.yahoo.com/group/pulsarsss/files/N14%20SR20DET/N14SSS-GTiR1.jpg
and another
http://www.streetcarz.net/cars.asp
http://www.autospeed.com/A_0101/page1.html my favourite
For wreckers see
http://www.japanesemotorsport.com.au/mainpage.htm
http://www.adelaidejap.com.au/cars.htm
http://wreckingyards.com/
http://www.cars-net.com/whoson.phtml
Lance
92 nx coupe
;0
;b
should sit in there same as the DE.
Yes the GtiR engine will bolt upto the gear box, but minus two bolts which is fine.
You would need the temperature sensor from your DE engine as the temp sensor that came with the engine is not calibrated with your temperature gauge. You will have 2 spares bolts after putting the gearbox back. I had to use my old Flywheel, side engine mounts are ok you may have to take some packing off the bottom engine support
beam.
Essentially any odds and ends (bolts) you can rip it off the old DE engine. I also use my old air con compressor because i know for
sure that it is working. well that's about it
>Hey,
>The DET clutch wont fit in the DE box....as I found out today - Im doing the Gti-R motor transplant too.
> >Catchya
> >Simon
It bolts straight in, you use your DE gearbox, you use the DET ECU, basically everything DET goes in.
You will need, new engine mounts(bushes), new exhaust, custom dump
pipe,etc. have look at the link below>
