1 - 2 of 2 Posts
So i have the stock exhaust off, almost. Only problem I have run into is what I believe to be the EGR tube that goes into the top right of the header. What can I use to remove it? Does it thread independently? What things did you all run into when installing a header on the sr20? Tips? Tricks? Thanks! I'll have pics later tomorrow night, after i get some races in!
-m
if you can squirt some liquid wrench or even WD-40 around the crack of the threads for the EGR tube and let it soak that'll help. make sure your engine is cold, the metal won't be as expanded. the tip of the EGR tube, once loosened will be able to slide up and down the tube. if you can get the opposite end of the tube loose, that helps a bit. good luck.
1 - 2 of 2 Posts
