One of the big waterhoses on the back of my engine is leaking, so I need to get my intake manifold off to replace it. I got off most of the nuts off on the lower intake manifold, but there is one that sits between the oil filter housing and the intake, really tight. I cant seem to get any tools in between there. How do you remove this nut?
You need to remove the oil filter housing. The power sterring pump needs to be loosened and pulled back to get enough room also.
Quick response :) I'll try that out. Thanks!
You'll probably have to work from below to get the oil filter housing off, as there's one bolt that's down low (it's a tall, skinny casting). Don't forget to mind the O-ring that seals the filter housing.
David
