I knew a guy with a turbo Accord that did that, and put a hood scoop on the side where the IC was. It will work, maybe you will have less lag since the air doesnt travel so much, but its more efficient to have it up front.
Fast91SER said:I knew a guy with a turbo Accord that did that, and put a hood scoop on the side where the IC was. It will work, maybe you will have less lag since the air doesnt travel so much, but its more efficient to have it up front.
You really dont have to worry about the radiator not getting enough cooling. I've never had a problem with overheating on the SE-R or the NX. But yeah, sleeper is always coolnissanoholic said:yeah, thats what i was trying for, less lag and more sleeper and better radiator cooling.
Fast91SER said:You really dont have to worry about the radiator not getting enough cooling. I've never had a problem with overheating on the SE-R or the NX. But yeah, sleeper is always cool![]()
Nitelife said:I actually saw a set-up like you described on ebay a few months ago. The guy had two DSM (Talon, Eclipse, Laser) SMIC welded together and they fit in the cavity left behind when the battery was relocated.
Like the others who have replied before, it seems like this would be a middle ground between FMIC and TMIC.
iNGEN said:I highly recommend you consider these:
http://store.yahoo.com/cheapturbo/pwr.html
Though more costly, much more effecient alternative. And will keep that sleeper look. Just mount the radiator(s) down in front of the engine radiator.
PSSSHHHGOESMYSR20 said:Like this?
They did that a long time ago seen here in this article. Personally Id rather mount it in front of the tire. But I hate small intercoolers as they tend to get heat soaked rather quickly.
Click Here
