1 - 2 of 2 Posts
Just wondering if this combo will trigger the engine light. Pretty much going to do this being that AZ doesn't check for EGR valve only a fuel charcoal cansiter and fuel evap system. will running the JDM Intake manifold trigger the engine light even on the JWT Turbo ECU? all information is much appreciated thanks
since 2001
I'm not quite sure what you are asking but i think i got the idea. On my set up I use a Jspec intake manifold with no egr and alsorun a JWT ecu. Before I ran the JWT ECU I would always have a check engine light but after the installation of the ECU it went away. I think you have to specify the problem when you order the ECU though.
Hope that helps...
.02
1 - 2 of 2 Posts
