Yeah,that was at the SoCal-SERCA dyno day. LM Frank Orozco got 60HP from a 50HP NOS set up with the JWT ECU w/NOS program. If I were going to use NOS,and I just may,I'd would definately go with the JWT NOS program.
The NOS program works several ways;1)It doesn't let the NOS selenoid activate untill your motor is above a set rpm. 2)It doesn't let the NOS selenoid activate untill your motor is a WOT. 3)It will make the injectors flow more fuel(up to their limits,which is why JWT doesn't recommend going past an 80shot with OE injectors)to prevent the motor from going lean. 4) And this is really important,the NOS program cuts off the selenoids several hundred rpm's before your rev limiter actives. Run NOS when the rev limiter activates and BOOM!
