1 - 2 of 2 Posts
I'm having troubles setting the timing with my JWT Ecu. I shorted the tps terminals per JWTs instructions but I can not get the idle below 900rpms, ontop of that it jumps form 900 to 1200rpms. Right now I have it set to 15 degrees with idle the way it is mention aboved. Is any one else having problems with their idle as well? any suggestions? TIA
Wait you have to short the TPS terminals? On mine all I did was unplug the IAC with the TPS and then I was able to get it down to 700-800rpm. But I have a 91 and you a 95 so maybe that is the difference.
1 - 2 of 2 Posts
