Well, I purchased a set of JWT S3 cams & did the install as per the instructions. I had the car @ TDC: 2nd mark from the left on the crank pulley, cam lobes (on # 1) facing away from eachother, intake cam dowel pin @ 10 o'clock & exhaust cam dowel pin @ 12 o'clock. I zip-tie the sprockets to the chain and put a block to jam the chain. I install the cams (20 pins dot to dot or 21 links) and tried to set the timing to 15 degrees. When I try to do that, I would almost have to fully advance the distributor (It should be in the middle)? Well, I tried to drive the car, I felt slower and weaker & hesitated once and a while. After break-in, I tried to race my cousins Integra & I lost.....I usually beat him pretty far! Anyway, I double check everything and I am confused by the whole situation. Anyway, my friend (who is a mechanic) & I tried to reinstall the cams.....same result? Then he thought that would should jump it by one pin....so we did. Everything @ TDC (intake @ 10 & exhaust @ 12, 2nd mark from the left on the crank pulley & the cam lobes facing away from eachother), we move the exhaust by one pin from 20 to 21 pins. I go to set the timing and what do you know, I go it to 15 degrees with the distributor in the middle! My friend & I are baffled by this. Well, my first impression is that the car feels stronger (SOTP) and it doesn't stall! Well, I have 40 miles on them and will wait to after they are broken in before I race my cousins Integra. Well, Any and all info & advice will be greatly appreciated.
Thanks,
KEN ABAT
P.S.
Thanks to Mike Kojima for all the HELP
Thanks,
KEN ABAT
P.S.
